I was just having a look again for a link that specifically mentioned "Panoramic" and "Verified View" and this hit popped up: https://www.ianhumes.co.uk/pages/methodology.html
He has breifly mentioned Panoramic in his methodology statement, and also quite kindly listed his email address and phone number if anyone needs more info. Perhaps you could send him off a quick email?
Also, from https://www.altonestateregen.co.uk/assets/regeneration/documents/may-2020-submission/esa-verified-vi... (Page 3 of the PDF States:)
"Overview The Arcminute system is designed to create geometrically accurate
photography and verifiable data for all its associated parameters and is fully
compliant with all guidelines covering images required to be aligned with
survey data for use in planning applications.
Equipment Images are captured on a 36mm x 24mm 36 megapixel digital
sensor in combination with the following lenses: 17mm, 24mm, 35mm, 52mm
and 80mm with shift capability (specially selected for best in class resolution
and customised to conform to the high precision focal length and optical
axis settings required in the process). Re camera mounts, custom made
designs for both single frame and panoramic capture are used to obtain high
precision camera positioning and orientation tolerances.
Choice of lens We prefer to replicate (as far as possible) what may have
already been provided in terms of preliminary view studies as typically
these would have been generated using pre-considered factors as to what
each view would need to illustrate e.g. context, key visual receptors etc. In
the absence of a definitive steer, we will generally use a 74o
HFOV lens for
medium to close views in an urban environment and a 40o
HFOV lens for
long distance views. However, the actual size and nature of a scheme (single
building or large multibuilding development) and its location will also be
considered before lens selection. The Landscape Institute’s latest guidelines
have been relaxed with regard to lens choice and they are no longer insistent
that a ‘standard’ lens be used wherever possible.
Photography The camera is set up at eye level (1.55-1.75m) and orientated
to within 0.02 deg of pitch and roll to the horizon. The point on the camera
that coincides with the origin of perspective is positioned in relation to a
survey marker to within 2mm in XYZ. The scene is then captured in a RAW
format using standard high quality architectural photographic practice.
For panoramic images the camera is setup in portrait orientation and rotated
around the camera coordinate capturing sequential frames with a 50%
overlap. Each frame has the same orientation tolerance as a single frame
capture. For every view, a photographic record is made of the tripod location,
the survey mark and the height reading of the camera above it".
Hopefully some more clues there.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
