Announcements
Output path does not exist- aborting render
brendamat
brendamat
I have been working in the same file and have been making changes to colors so that I have saved a new file with the changes. Why am I not able to render and how do I fix this?
I am pretty new in 3dsmax and I do not know the program well, so I work just with recoloring and text/bitmap changes.
10DSpace
@brendamat
Check the common section of the Render Setup Dialog and see if "Save File" is checked and if so what file path shows in the Render Output section.  The error message you are getting says that the file path does not exist, so verify this and if so adjust file path accordingly.  If your file path is to a network location, try as a test changing the file path to a local drive to rule out network connectivity issues.
If you are still having problems, post screenshot of render setup dialogue.
brendamat
thanks a lot! It did work 🙂
javierfmNCLCK
Community Visitor
Community Visitor
so thanks
