Objects not affecting sub-objects
Ryawy
Ryawy
I've never seen this happen before and I don't know what could have caused it. Objects in a hierarchy aren't affecting their sub-objects at all. This issue happens even after I reset the scene and all of the inherit boxes are checked.
https://imgur.com/a/gc0q5SE
10DSpace
@Ryawy
Check also to see if  "Don't Affect Children"  is activated in the Pivot section> Adjust Transform  of the Hierarchy tab.  That would also prevent the child object from moving if it is enabled.  I noticed that it gets stuck in max 2020.3 and you cannot toggle it off except by switching out of the Pivot Tab.
Ryawy
Nope, that didn't change anything. It wasn't toggled on, and toggling it on and off didn't change anything.
BenBisares
Autodesk Support
Autodesk Support
One more thing I would check is the "Inherts" under Link Info. Make sure that everything is checked.
If it's not that, can you attach an archive of your scene? I would like to take a look at it.
Ben Bisares
