Objects Breaking in Render
blenderwala
Message 1 of 8
blenderwala
I am Trying to Create PBR Materials Using Material Texture Loader Script. It's Working fine in Viewport. But when i render the scene it is just breaking the entire scene.
Please Guide me through the issue.
VRay-5
3DS Max 2020
Material Texture Loader 1.40
Replies (7)
Message 2 of 8
10DSpace
@blenderwala
Looks like you may have a normal map that has the wrong Gamma setting.  It should be set to 1.0.  You can do this manually by opening the map in your normal map slot and in the resulting dialog,  click on override for Gamma and set to 1.0.
Message 3 of 8
10DSpace
If normal map fix doesn't work, it could also be the displacement map, if you are even using one.  Again, it should be set to Gamma of 1.0.
Same for a height map if you are using one in addition to normal map.
Also sometimes even with Gamma = 1.0,  the displacement map settings can be too high,  so try lowering displacement amount if the correct Gamma doesn't fix it.
Message 4 of 8
blenderwala
I Tried to change the settings as you suggested but its not working. It would be great help if you guide me to what options to change exactly.
Thanks for your quick response...
Its working Fine In Other Computer
(3DS Max 2016, VRay-3.60)
Message 5 of 8
10DSpace
@blenderwala
The gamma setting I was referring to is shown below.  It is accessible when you click on the bitmap placed in the Normal map slot (or displacement map slot).
If you already made this change to your Normal and/or Displacement map,  and it's not fixing the problem, then post your max file here and I will take a look to see if I can find the problem.
You can also narrow down the problem to which map might be causing the problem by unchecking it in the material editor.  There is a checkmark beside each map channel (see below)
 Try rendering with the Normal map (and or Dispalcemnent Map) unchecked and if you don't get the distortion of the mesh you are seeing then you know it is that map.
Like, I say, if you are still having problems, post your max file here.
Message 6 of 8
blenderwala
You helped a lot. After turning off the displacement map everything is fine. Just i am not getting the gamma option like you.
Please have a look. I am quite new to Max
Here is my Max File:
Error File Archive
Message 7 of 8
10DSpace
@blenderwala
Good.  So now we know it is the displacement map and/or settings that are the problem.  I see from your Max file that you are using a VrayBitmap (vs a standard bitmap in Max) which allows you to set the gamma in a different place.  See image below.  For your displacement maps your gamma is correctly set to 1.0 as shown below.
So the problem may be that the displacement amount is too much and you can test this by changing the displacement amount from 100% to something like 10% or even 1-3%.  (see my message # 5 above, the second image, to see the spinner next to the displacement channel that you need to change which currently reads 100%) For ashphalt and wood you do not need a dramatic amount of displacement.   In fact a Normal map alone (without displacement) is probably good enough for even medium distance viewing.  But so that you learn to control the amount of displacement, you should play around to find the right value.
If you are still having problems, zip up the actual Displacement and Normal texture maps in your scene and post them here and I can have a look but maybe just lowering displacement amount will fix it for you.
Message 8 of 8
blenderwala
Solved... After reducing the displacement map value the problem is now completely resolved. Thank you all and especially @10DSspace for such quick response, you have guided in great detail.
Although I have found another solution , if you have the latest VRay just apply the VRayDisplacementMod modifier and copy the displacement map to the texture and finally check the Keep Continuity option.
