nothing appears in render
jaskaranjotsingh13
jaskaranjotsingh13
Community Visitor
Community Visitor
Hi guys,
Struggling with rendering at the moment. For some reason only the sky and a grey ground appear in my images even though there is a building there to render too. the first image is what is in the camera view and the second is what the render comes out as. Any help would be much appreciated.
darawork
Couple of things:
Make sure that the Virtual Frame Buffer (Rendering window) is actually rendering the correct camera, it is currently rendering Camera 2... is this the correct Camera?
Right click on the objects that are not rendering, go to their properties... and check that they are set as 'Renderable'.
Materials are one sided, and the normals are flipped inside out.
Try creating a new camera, and rendering the same view.
Some other checkbox, in the Rendering Setup Dialogue (Render Engine dependant) has been set not to render Geometry. Might be the Direct Visibility Overrides section.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
AVOLOSATOV
Community Visitor
Community Visitor
Did you solve this problem? I have the same.
