I am trying to create animated cables for dental equipment. I have connected the ends of a straight line to dummy nodes. To set an initial state, I have moved the end nodes to the determined locations.
Cables seem to behave ok. initially but they continue to twist even after predetemined node motion stops.
The definitions of parameters in the documentation don't help decide which parameter I should tweak, without testing and it is a tedious task to one by one change parameters, simulate and retry.
Can anyone supply a quick parameter tip that will help relax the cables without sagging or turning the circular cable section into an ellipse.
My settings are in the image. I have attached a preview, too.
