Need help baking textures onto a PNG file (Diffuse map)
mra16r
Observer Observer
mra16r
Observer
Observer
I need help for baking the textures on my 3D model. It's a 2 million polygons model from sketchfab, but converted to 200'000 polygons with "ProOptimizer" modifier.
The model has all the colors and textures in the 3D viewport. It's just when I try to export the textures, it shows it can't find the diffuse map for some reasons.
Video of what I did:
https://streamable.com/s27xyt
Don't hesitate to ask me for the complete 3D model project (bought from Sketchfab), if you want to test it for yourself.
Diffus3d
Hello @mra16r ,
Might be a couple things.  First, make sure your textures are properly linked up in the Asset Tracker.  (File-> Reference -> asset Tracker Toggle.)  Chances are that's the problem.
The possible alternate thing it might be is that those are inside a material which isn't supported for baking with the current renderer.  I feel like the message would be different if that was the case though.
Best Regards,
mra16r
Observer
Observer
Thanks, I just did this but it still can't find two image files for some reasons. I can't even find them in the project I bought from Sketchfab.
If it's not too much trouble, can I just send you the project files, and you could try to do this on your end?
I've been trying to fix this for 3 days and I'm just not good enough I guess.
Here are the project files:
https://we.tl/t-VsiWPrbdlS
Diffus3d
Hello @mra16r ,
It wouldn't help, you'd still have to link them yourself since your folder structures are different than mine.  If you are missing textures, I also couldn't really help there.
What part is tripping you up?
Best Regards,
