AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
MOVE WITH AXES ISSUE
lazzari-mattia
Message 1 of 8
lazzari-mattia
It seems that in 3ds max 2022 the movemet along the axes  is having some issues.
I cannot move my object by selecting the axes (just see the video attached here to better understand my problem).
Is someone else having this problem or is it just me?
Is there a way to make this work properly?
Thanks a lot!
Replies (7)
Message 2 of 8
shawnolson
What version of Max are you using?
Is this happening with all objects, or just this object?
I noticed that in your video, when you click what appears to be the Z axis (blue) it switches to the Y Axis (green). This leads me to think that the object may have a bad Xform. If the current transform is not important, you can try selecting the object, clicking Utilities, hit the Reset Xform button, then click the Reset Selected button. It's just a shot in the dark, but it might fix a bad transform.
Message 3 of 8
lazzari-mattia
Hi and thanks.
I'm using 3ds max 2022.
It happens not with every object but with many objects; sometimes it seems that this problem does not exists, sometimes move with axes is impossible to me. Sometimes an object seems to have this problem, but after some tries the problem is not there...I can't understand why!!
I will try the tip you suggested the first time I encounter this issue, but if I'll have to do this every thime it would be frustrating... 😞
Message 4 of 8
oliver
Which coordinate-system is set?
Message 5 of 8
lazzari-mattia
I'm using "View".
Message 6 of 8
shawnolson
Did you end up encountering the problem again? If so, did you try resetting the object xform?
Message 7 of 8
lazzari-mattia
yes the problem is still there. I tried with reset x-form but it didn't solve the problem.
Message 8 of 8
aranmor
Hello, Did you find a solution? I'm having the exact same problem
