Move Transform Type-In Missing
Message 1 of 9
HI,
I've been using 3dsmax 2012 for some time. I have always use a big display monitor , but now i change into a smaller monitor. The only problem is that the Transform Type-In Dialogue is missing. I think it's hidden outside the monitor and i couldn't get it back. I tried using the bigger monitor and the problem is solved.
RIght now i need to use the smaller monitor. Is there any way to find the dialogue back when i'm using the small monitor?
Thank you.
Replies (8)
Message 2 of 9
rendermaster
alternatively, you can use Move Transform Type-in dialog box by right clicking on the Select and Move Button at the Main Toolbar
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 3 of 9
Rendermaster thank you for replying.
I've always right click on the move button. The dialogue always appears, but now its not.
Message 4 of 9
rendermaster
check this out: http://www.scriptspot.com/3ds-max/scripts/reset-3ds-max-windows
and this: http://lonerobot.net/?p=710
and this: https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
Message 5 of 9
Alfred.DeFlaminis
Hello @Anonymous,
Welcome to the community!
The way I like to solve these types of issues are with the following keystrokes, please let me know if they do not work for you.
Right Click to open the Move Transform Type-In dialogue
Alt + Space
Press "m"
Down Arrow
Move the mouse and fixed.
Please hit the "Accept as Solution" button if my post fully solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
Message 6 of 9
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on your issue?
Best Regards,
Message 7 of 9
Hi @Anonymous.DeFlaminis,
The trick doesn't work.. sorry..
Message 8 of 9
Hi @rendermaster,
The Third option from autodesk.com works.
I just delete the 3dsmax.ini and restart my 3dsmax. It goes back to the default settings.
Thanks for the help!
Message 9 of 9
Alfred.DeFlaminis
Hello @Anonymous,
Thank you for the follow up, I've gone ahead and unmarked one of the solutions.  I'm glad that it's all set for you now, have a great week!
Best Regards,
