Move Icon Malfunctioning when there is floating viewport
arq_alberto_soto
Observer Observer
arq_alberto_soto
Observer
Observer
Whenever I have a new floating vieport, on another screen. Move Icon rotates in weird angles, that makes very dificult to move things.
Is there anyway to fix that?
RobH2
Does it happen on every floating viewport? Can you do a screen grab and show what's happening. I tried to reproduce it and was unable to based on your limited description.
If you could list the steps you are taking prior to the problem ocurring I'll try again.
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
arq_alberto_soto
Observer
Observer
Hi I recorded a small video to show you the issue I've been having after working some time with some medium size scenes. It ussually never happens with a new small scene, with only a few objects.
https://youtu.be/J04q9QmRkME
Greetings,
RobH2
Thanks for doing that video. I see what you mean about the issue and I think it's a bug. I get in now and then as well and it's as if I have to chase the gizmo around but it keeps jumping away and I can't catch it. Generally, I eventually give up and move the object with the spinners on the toolbar. You can hold 'Alt' as you use the spinners so that they move in smaller increments which often helps.
I'll experiment some more but I'm not sure there is anything you can do about it. Try using the spinners when it happens and it would be good to go report it as a bug. You can do that here:
Bug Reports-
https://www.autodesk.com/company/contact-us/product-feedback
Rob Holmes
