Thank you for the reply.
I couldn't find any defaultui.musx in the path you've provided. That's why I thought it was in the 3dsMax root at Program Files.
So I created one by changing the file manually and saving it. However upon starting 3ds Max, it will disregard it and it's still the default 1.0.
The reason why I want Max to use my customised maxstart.max is because on opening a new file, I need the following:
1- unticked Auto-Expand to selection in Layers (default is always ticked)
2- PAL and range 0-100 (default is always NTSC)
3- Linear animation tangents (as an animator, we prefer starting animation with this type of tangents)
4- Units setup in Centimeters (that's what we use here)
5- My own preferred Layout, toolbars and menu (it always open the default workspace and I don't want to change this in case I need to reset, so I rather prefer saving my own workspace)
I tend to have repetitive strain injury when using 3ds max due to many clicks here and there. When I use Maya I need to conduct less clicks because of its famous G key to always repeat ANY last action PLUS its highly efficient scripting for automating tasks. Max Listener does not record EVERY ACTION you perform annoyingly...
Hence my use of Maxstart.max file... to minimize repetitive tasks...
I could ask my boss to get rid of permissin policy here but it's unlikely that this would happen.
Now your questions:
1- You don't need to use the template manager to load a MaxStart.max file. That happens automatically when you start Max regardless.
How is this possible without maxstart file ? I would like all 5 items in the top happening on loading 3dsMax
2- Do all the users in your group use the same login? If not, you should be able to customize Max however you like and not have to worry about the next person's settings.
We all have different logins. So can I go bonkers with changing 3dsMax settings unlimitedly ?
I was thinking of another solution to force 3dsMax to apply my Wheel Zoom Increment when starting: saving a script file in the startup folder.
I tried with no success. I don't know much about max script, only mel. Is this possible ? How can I do it ?
Thanks again.
Vicky
