I am having an issue with some vertices not showing up on the model. For some reason they show up on the backside of the geometry. Also having in issue where the geometry disappears from an object. If I click on the object it will come back, when I click off of it, the geometry fades away, but would like to see it all the time like you would normally.
I have had this issue in the past where I upgrade an old model. If I create new geometry in the same file everything works and displays properly. I am working on some old models, fixing geometry and making them look better to update my portfolio. I’ve tried converting to an editable poly again, tried converting to a mesh and back to a poly. Backface culling is not on. The ‘Show end result’ button is not clicked. I’ve gone into edit the object and show vertices, polys, objects. I have read through forums and watched videos and am not finding a solution. I would prefer not to spend months remodeling everything and see if there is a way to fix this issue.
I’ve attached one of the models that I am having this issue with, but I do have quite a few models I am working on. I would love some expert advice. Thank you.
