Missing 'scene states manager'
This widget could not be displayed.
I can't get the 'manage scene states'-window to pop up. Tried to access it both thru the quad-menu as well as the tools-dropdown. Is there anybody out there, with the same problem?
I've used it in previous versions, where it worked fine -for me.
Replies (29)
kommajoost
<EDIT> Right after posting this it somehow worked, not sure what I did in the meantime though... <EDIT>
Still having this problem... 3ds Max 2016 SP2 with Windows10
I'm allready admin so changing to admin and restarting 3ds Max cant be it.
Also deleted the ENU but that doesnt seem to help..
Can anyone help? I cant really reinstall 3ds Max since I have alot of plugins...
Same problem here. Windows 7 64bit max 2016 sp3. Can't get the scene manager work.
bill14
I have the same problem in 2016 sp3 on Win 7 Pro
gregg_lagnese
Deleting the max pref INI in the user's personal settings folder fixed this for me.
.....Gregg
Gregg Lagnese
Senior Technical Account Manager
(240) 888-9744
gregg.lagnese@autodesk.com
Sent from a mobile device
romullus3d
Adding additional strings to max.ini file cured the problem. Thanks ^lele^!
bill14
Thanks-I got it to work!
Where I can found this max.ini? What is the path that is located? Could you send me the steps?
gregg_lagnese
The path to the INI is here: C:\Users\[your userid]\AppData\Local\Autodesk\3dsMax\2017 - 64bit\ENU The easy way to open this directory is to type '%LOCALAPPDATA%' into your run field in the start menu. Then drill into Autodesk\3DsMax...
please how can i add additional strings to the .INI???
悠長崎3770
You can open ".ini"file  with Notepad App in Windows.
