miauu's Drag&Drop Pro
miauuuu
miauuuu
miauu's Drag&Drop Pro makes file handling in 3ds Max faster and smarter by adding intelligent drag-and-drop functionality for assets, proxies, and materials.
What can it do when you drop files from Windows Explorer into 3ds Max?
  • Automatically relink all missing textures on file drop.
  • Instantly open dropped proxy files in the viewport.
    • Supported proxy formats: V-Ray, Corona, and FStorm.
    • If a matching .mat file exists in the same folder, it is auto-assigned to the proxy*.
  • When dropping a .mat, .jpg, or .png file, the matching proxy file* loads automatically.
  • Apply materials to the object under your mouse when dropping a .mat file.
  • Drop a shortcut (.lnk) file — and it opens the file it points to.
* The proxy file, .mat file, and thumbnail file must have the same name. For example:
You can find more information here: miauu's Drag&Drop Pro
https://miauu-maxscript.com/
miauuuu
miauu's Drag&Drop Pro has been updated to version 1.1.
Changelog:
- added support for dropping multiple files and folders
- added support for network files and folders
miauuuu
miauu's Drag&Drop Pro has been updated to version 1.2.
Changelog:
+NEW: "Create Layer per File": When a MERGE .max file is used, the objects from each merged .max file will be placed in a new layer with the same name as the processed .max file.
+NEW: "User-Defined Search Folders": You can add arbitrary folders to be searched for replacements of all missing assets.
+NEW: "Extract Archives (.7z, .zip, .rar)": Dropped archives will be extracted (including nested archives), and all extracted files will be processed by miauu's Drag&Drop Pro.
+NEW: "On .mat File Drop in Slate Material Editor": When one or more .mat files are dropped into the Slate Material Editor, the materials from those files will be loaded in the currently active view of the SME. The missing assets in the .mat files will not be relinked.
miauuuu
miauu's Drag&Drop Pro has been updated to version 1.3.
Changelog:
+ NEW: Group objects by dropped file. The group name matches the dropped file's name.
+ NEW: Offset the contents of dropped files to prevent overlap.
