Maxscript Rollout Handler Exception
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 316093; line: 8524
-- MAXScript Rollout Handler Exception:
-- Runtime error: Skin need to be selected and in the modifier panel Skin:Skin
-- MAXScript callstack:
-- thread data: threadID:3688
-- [stack level: 0]
-- In i loop; filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 307324; line: 8328
-- Defined in encrypted script
-- [stack level: 1]
-- called from FN_buildArm(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 316094; line: 8524
-- [stack level: 2]
-- called from i loop; filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 167375; line: 4339
-- [stack level: 3]
-- called from FN_build(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 168463; line: 4378
-- [stack level: 4]
-- called from i loop; filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 165778; line: 4276
-- [stack level: 5]
-- called from FN_build(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 165783; line: 4277
-- [stack level: 6]
-- called from FN_buildRoot(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 236309; line: 6464
-- [stack level: 7]
-- called from buildBtn.pressed(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 456625; line: 11509
-- member of: Rollout:startupRoll
-- [stack level: 8]
-- called from top-level
I am problem so that InstantRig install for this is Maxscript error. Can you help me?
CAMedeck
From what the error message says, you will need to have a Skin modifier applied to your model, and you need to be in the Modify Tab of the Command Panel with that object selected.
You have set your replies as Solutions, so your original question appears as being solved which will make it less likely to be viewed and help given.  'Accept Solution' should only be selected when a reply fixes your problem.
Chris Medeck
Of course, message you. I do not mean small things. Now I accept the chaos attempt.
