MaxScript error when scenes load (garbage collection)
renar-visuals
renar-visuals
A couple of days ago I started getting Maxscript error almost every time I load a scene. This happens immediately after a scene loads and affects every scene, not just ones belonging to one particular project. Restarting Max, as the error message suggests, doesn't fix the problem and I still get this error next time I run Max. I get this error even when merging scenes.
Please check the attached screenshots. When I click "OK" I can proceed to normally work on my scene until the next time I load a scene and the error appears again.
3ds Max subscription customer since 2010
| Max 2022.1 | AMD Threadripper 3970X 32-core | 64GB RAM | Nvidia GeForce GTX 1080 Ti FE 11GB | NVMe SSD Samsung 960 Pro | Win10 Pro x64 | Nvidia Driver 466.47
jonathan.matthews
Hello office-
Thank you for your forum posting.
I have seen this error with maxscript before and a simple reset of 3ds Max did the trick. Please try resetting 3ds Max.
Looking forward to hearing back from you soon.
Best Regards,
Jonathan Matthews
Autodesk Technical Support.
renar-visuals
Thanks, I think this fixed it! 🙂 So far I've not had this error message. I'll post if it happens again.
