Maximum render size
Maximum render size
Maximum render size
What is the maximum render size can max or maya can take using redshift or V-Ray?
Thanks.
Alfred.DeFlaminis
Hello @Anonymous,
I'd like to answer your question here.
The maximum native res for 3ds Max is 2^15th or 32768 x 32768.  With the Vray Frame buffer, you can go to 50,000 by 50,000.
In Maya, the limit is only your available RAM and the ability to render without a crash, but for some res's you need to use batch.  Not sure about Vray.
You may have to ask on Redshift forums for the Redshift maximum resolution.
Best Regards,
MR. Alfred (AJ) DeFlaminis,
Thanks for the feedback. I will check with the redshift.
Alfred.DeFlaminis
Hello @Anonymous,
If you find an answer about Redshift, please post it here and I'll kudo your post.  It'll be nice to have all the info in one place in case a future user is looking for it.  Thank you very much!
Best Regards,
Hello Alfred (AJ) DeFlaminis,
Definitely I will update information about redshift once I come to know.
Thanks.
I have an update to the above conversation.
The maximum render size can redshift  take has no limit or your computer memory.
Which means The sky is the limit or your system RAM, Graphic, ETC....
Thanks.
Alfred.DeFlaminis
Hello @Anonymous,
Thanks for the update!  Kudos and solution given and thanks for taking the time to update the thread.  Have a great week!
Best Regards,
