Max8 on win10
Max8 on win10
Max8 on win10
Hey there. Im working with max12 but i need max8 now for some things i need that will only work with old plugins of a game.
The programm installed and works well but always when i right click the place where the righ click window opens it freezes on the display. Not only max, its everywhere until i close max8.
I hope the picutre shows what i mean. I tried compability mode, start as admin and different drivers = all the same problem.
You guys have any solutions? I dont want to believe that this is not fixable once all other things in max work very well under win10.
Thx in advance 🙂
its not compatible with windows 10 & never will be
autodesk won’t fix it
but everything works despite this little annoying "bug". I found a solution on the web but it doesnt work for me 😕
https://webcache.googleusercontent.com/search?q=cache:u08OPvUx-rIJ:https://www.fsdeveloper.com/forum...
irishman_team_kilber
I have windows 7 and 3ds max 9 you will have SP2 installed https://knowledge.autodesk.com/support/3ds-max/downloads/caas/downloads/content/autodesk-3ds-max-8-s... but you mite get a windows BEX error
no problem is if you don't have a serial number and activation code then you cannot active it. because autodesk stop using the old serial number and they stop issuing new ones.
http://www.cgchannel.com/2019/06/autodesk-to-stop-issuing-activation-codes-for-older-software/
