max2017 - OBJ import with multimat broken?
danny
Message 1 of 12
danny
Importing OBJ's with multimat textures seems not to be working in max2017, only the first material is imported.
In max2016 this works fine.
Can this be confirmed as a bug?
thx,
Danny
Replies (11)
Message 2 of 12
thx,
Danny
I think this was fixed in SP1 even it doesn`t say so in the release notes. I had that with the initial 2017 release but now it works as expected.
Message 3 of 12
danny
Thanks for your input, I am actually using Max 2017 SP1.
Maybe it is something about my setup...
May I ask you to test the small attached scene?
scene.max - max2017 testing setup scene with multi materials
OBJ2017.obj - the exported OBJ
> only 1st material gets imported back in 2017, works fine in 2016
Thx!
Danny
Message 4 of 12
Ok, this is what i found so far:
If you export/import obj from 3dsmax it indeed truncates all materials except the first one.(using the example scene you provided)
If i use an external application for exporting obj ( in my case i used Poser/Daz-Studio) it works just fine and all materials are
forming a nice multisub-material in 3dsmax2017.
However if i import into DAZ/Poser from 3dsmax2017 i get all sub-materials but the cube is not visible in the viewports of these applications.
So i guess obj. export is broken in 2017.
Do you agree? Or anyone else?
Message 5 of 12
danny
I also tested with DAZ obj exports and same problem >  just 1 material in max2017 (works fine in max2016)
Also with obj's from marvelous designer.
When I export OBJ from max2017 they do seem to work fine in other applications. (tested with max2016 and element3D)
But importing OBJ into max2017 always gives me problems.
Cheers,
Danny
Message 6 of 12
Ok, i`m starting to realize that material handling of .obj import in 2017 works different from 2016.
If you uncheck 'import as single mesh', it no longer creates a multi-sub material for all scene objects.
Instead it creates a material/submaterial of the materials assigned to the specific object only.
Only if you 'import as single mesh' it creates a multi-sub of all objects in the scene (which is the default behavior in 2016)
This rather looks like a well-meant optimization in 2017 than a bug.
Message 7 of 12
Hmm, i still can`t import an object exported from 2017 with multiple mat-id's. Strange.
Message 8 of 12
I am having the same issue importing. Submitted a bug report back in 4/16. Applied sp1 and still have the issue.
Right now my work around is
Import into 2016
Save as .max file
Merge into 2017
Message 9 of 12
danny
Yes, that is also how I manage my workflow for the moment.
Thanks for confirming, hopefully this gets solved in the next SP.
Cheers,
Danny
Message 10 of 12
Switched to .fbx because of this. Hope this get fixed though.
Message 11 of 12
Installed Sp2 and this still isnt fixed.
Smiley Sad
Message 12 of 12
Has this even been solved? I can not export IDs with OBJ and using Max 2016 certainly makes no sense.
Yes, I know I can export IDs with FBX but in some specific cases I need OBJ
