With all previous versions of max, we where able to save in the last 4 years of versions, for example max2014 can save all the way down to 2010. Knowing this, when i purchased 2015 i was met with the VERY nasty surprise that it only saves to 2012. I NEED to be able to save in 2011 format. How do i make that happen?
Thanks for the answer, after more searching (which i should have done, my bad) it does seem like its only the previous 3 versions are supported.
Silly, but save in 2014 and from there to 2011. Or you can export fbx. Personally, 2012 is the oldest Max I'd use anyway. It's the first true modern Max all later were built upon.
