Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Max Gizmo not working (Only move key is not working)
1 REPLY 1
pratapmistry26
580 Views, 1 Reply
Hello there,
My max move shortcut key which is W is not activating the move tool. But I select it from the top icons bar its working and also other keys like E for rotate is working and R for scale is also working but W is not working. My keyboards W button is also working. I have checked every setting and all are at defaults and correct.
please, check the screencast video I have attached for a better understanding.
Tags (1)
Labels (1)
1 REPLY 1
jon.bell
in reply to: pratapmistry26
Hi @pratapmistry26,
Thanks for your message. It's tough to tell from your video, but are you not able to move your objects at all? If so, then you may have accidentally changed the default controller type to something that doesn't respond to direct mouse movement on Transform gizmos (like a Path controller, say).
Can you try resetting your 3ds Max preferences back to their default settings and let me know if this works for you? Thanks!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
