Max fluids dlo are missing is 3dsmax 2021/2021.1
bigonethegod
bigonethegod
Hello! Am i the only one who is having this problem with 2021 version? I have a scene with liquids in 2020 and i need it to open in 2021.
Need help!
P.S. I tried to reinstall it a few time and also tried to copy missing folders dedicated to maxfluids from 2020 files but it didnt work out.
RobH2
I know this doesn't solve it for you but  I'm just reporting in.
I have no errors like yours with Max 2021 or Max 2021.1. I 'DO' have 'MaxFluid.dlo' in the following folder without manually putting it there:
'3ds Max 2021\ApplicationPlugins\MaxFluid\Contents\bin'
I hope you find a solution. Maybe resetting the ENU? Search for that if you don't know how to do it. Lot's of threads on it and it solves a lot of problems sometimes.
Rob Holmes
3ds Max (2023-2026), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
I have a problem like this too. When I import a fluids scene from 3ds max 2020, everything works properly. But when I want to make a fluids scene in 3ds max 2021, the plugin doesn't exist.fluids_missing.jpg
nano_langenheim
Same problem as above.
Fluids do not appear in the drop down
N-particle
ard-nax
Same problem here. Fluids menu is not exist in Create menu...:/
