Max 2024 Slate Material Browser - Bitmap options not visible
kokolioko123
kokolioko123
Recently I have updated Max 2024 to the latest Fix and this happened. Whenever I try to amend something within any bitmap's options (Coordinate, Bitmap Parameters, Output etc) the menu is cut-off, visible on the screenshot below.
The system is Windows 11.
Any ideas?
kokolioko123
Anyone?
hakankurtulus_pr
Hi, do you have any solution l am in the same problem, Once l find and try that change the 3dmax file high DPI settings not work for me.   Thank you.
matthewfkc79
Community Visitor
Community Visitor
any solution?? i have the same problem too
need to use corona bitmap to avoid from this
