Max 2024 Open Preview Window not update automatically
rasyidxtreme1
Observer
Observer
rasyidxtreme1
Observer
Observer
Somehow 3Ds Max 2024 'Follow Current Selection' in Open Preview Window slate material editor is not update properly (not work the same as previous version of the 3Ds Max), I'm using VRay for the material. For instance case after unlink node that are linked to material node, the preview window somehow didn't keep with the Follow Current Selection and turn back to default selection. Please kindly see the attachment below for clear information. Thanks.
Replies (7)
darawork
It appears that there has been a whole host of problems with the 2024 SME.
If the problem you are experiencing was not fixed with the 2024.1 update please submit product feedback under the Menu Item [Help]-> [Feedback]-> [Report a problem...]
Hopefully with enough customer momentum this might be fixed in 2024.2
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
rasyidxtreme1
Observer
Observer
Noted, thank you for your advice.
pg.macri
Observer
Observer
same issue... autoupdate not working
michaelaskew6543
Observer
Observer
It appears that there is an issue with the "Follow Current Selection" feature in the Open Preview Window of the Slate Material Editor in 3ds Max 2024 when using VRay for materials. Specifically, after unlinking nodes that are connected to the material node, the preview window does not maintain the "Follow Current Selection" setting and reverts back to the default selection.
To better understand the problem and provide clearer information, could you please attach the relevant file or screenshot that demonstrates the issue you are facing? This will help in diagnosing the problem and providing appropriate solutions or workarounds. Thank you.
Regards:
apkfik
pg.macri
Observer
Observer
also physical materials dont auto refresh in the material editor....
ads_delesdr
@pg.macri We haven't seen any problems with the SME thumbnail renderings. Are you sure you have them enabled? It's easy to miss that teapot icon at the bottom left of the SME UI...
Rick D
Senior QA Analyst - 3ds Max
pg.macri
Observer
Observer
yes now works ....  .. my bad I did not notice it...thank you
