Material missing in obj export
I read several post related to OBJ export issues and unfortunately I haven't really found the answer to my problem. My test case is creating a building from a simple cube converted to poly and then slice the cube creating 10 faces. I created a multi-sub material and mapped 3 jpg textures to create commercial, residential, and rooftop. I exported the building to OBJ and looking at the MTL (material) file it doesn't list my JPGs. I've tried several setting changes and no luck. I compared an OBJ/MTL file that works correctly and the formats seem to be a little different. Can anyone provide some insight on this? I attached the the 2 MTL files for your viewing pleasure. Thanks for your help.
Steve.
jonathan.matthews
Hello.  Below I have pasted a few links of forum postings, an article and a video about exporting to OBJ with materials.  Please review them and let me know if they are of any help in your situation.  These links have helped other users before with the same or similar issue.
http://forums.autodesk.com/t5/3ds-max-3ds-max-design-general/materials-not-applying-to-models-after-...
http://forums.autodesk.com/t5/3ds-max-3ds-max-design-general/exporting-obj-files-and-keeping-the-mat...
http://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/3DSMax...
https://www.youtube.com/watch?v=Uc_nW-W1LOA
Thank you.
p.s.
The case that was opened with tech support in regards to this forum posting will be closed as I will continue to follow up with you here on this forum.
