Material Editor and other windows are TOO WIDE
These windows are too wide and I don't know why. How to change their size to normal? It's a bit uncomfortable to use them right now.
  • UI
darawork
Hi, this seems quite normal to me.  Unfortunately these windows can not be resized. What is your desktop resolution? Are you using a dedicated PC monitor or a TV? I'm using a Sony TV with the resolution set to a native 1920x1080 (recommended) and this is what I see. It is very helpful to use two monitors if at all possible. Unfortunately because of Covid I am working from home and don't have access to two monitors anymore.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
I use two monitors, the main is AOC C24G1, which is FullHD and I set 1920x1080 (recommended). Everything was good but I reinstalled Windows, installed 3Ds Max 2020 again, and saw this.  So it is not comfortable and I think it's possible to resize these windows but how..
darawork
You can resize windows inside 3DSMax with this little piece of software. I've used it before for other applications, and I just tried it now with 3DSMax and it works too.
https://windowtop.info/
Darawork
AutoDesk User
Yeah, I changed size but this looks funny 😄 Unfortunately this is not the way how the Material Editor needs to look like. I still have this strange scale mode
