Map Types missing in Material/Map Browser
I'm missing things like the Falloff map, Particle Age map etc from the Material Map Browser.
  1. I click the Diffuse Map button on a standard material.
  2. The material/Map Browser pops up.
  3. Under maps I don't have a Standard section... Which is where I used to see things like the Falloff map etc.
How do I get the missing map types to appear?
This is in Max 2018 Student.
darawork
The first thing I'd check is that you might have selected a different rendering engine. Not all standard materials are compatible with all rendering engines.
You can select to 'show incompatible' via the menu drop button on the material map/browser window;Untitled.png
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
Thank you! That has been bugging me for ages!
