Locking my "view to render" is not working
vanderloo5
vanderloo5
Is there another setting I should know about to make the "View to render" stay locked on my camera view when I switch viewports? I have the lock set but every time I switch viewports the IR changes to that viewport.
MartinBeh
Can you show us a screenshot on how you locked the viewport?
Which renderer is this about?
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Casey_H_
Similar to your other post, I believe the IPR settings are set to viewport, so when the active viewport changes, so does the IPR, ignoring the lock that is set in Max. Set the IPR to use VFB instead of viewport. Think of Corona settings as "above" or "on top of" the Max settings, so the lock in Max settings are base, then Corona settings above that modify them.
vanderloo5
Thank You Casey. I switched "area to render" under the common tab in Render setup from "view" to "selected" and it seems to be locked on the camera view now.
