keyboard shortcuts not working well
Hi there, I'm new here.
Used Max for several years, archviz mainly. Having a problem since 2018.4 upgrade:
When I select an editable object in the 3dview, I should be able to press '1' and got to vertices, '2' for edges etc. The problem is that when I select it, I have to click on it again before this keyboard command works. Also, to toggle out of sub object mode by pressing 1, 2 etc , I have to press click on the 3d view to deselect all subobjects. Also, Ctrl-Z (undo) seems to require deselection of all objects then another click before it works, even if I have just completed a command i.e. not clicked out of the 3d view to another window etc.
Every keybpoard command seems to require a 'pre-click', and its slowing me down massively, I can't get into my flow.
Anyone know if I've toggled something or have they also seen this strange behaviour?
Thanks in advance.
Rob
