Announcements
Keeping an Object Oriented Perpendicular to Path?
stusic
stusic
I'm trying to animate an object between two splines and would like to keep the object perpendicular to the splines (like the axle of a train staying perpendicular to the rails).
I've set up the object to follow path on one spline and set up a LookAt constraint on a dummy that's path constrained to the other spline. It almost works, but since each spline is a different length (they're twisty and curvy), one Path Constraint outruns the other and my object ends up becoming slanted towards one or the other.
Am I doing this correctly? Is there a better method to keep the object oriented like I want? Thanks for any help 🙂
Diffus3d
You can use the "follow" checkbox to keep it aligned, and you can use the normalize spline modifier to ensure they move at a constant rate.  If your objects still seem to change direction in route, then use a helper on the spline constraint and link your model to the helper.  Then you can adjust the link info to not inherit certain transforms.
Best Regards,
stusic
Thanks Alfred, that was helpful. I tried it this morning and got it to work 🙂 However, last night I tried doing it in Tyflow and got very good results with that approach. I think I'll go that route this project, but this will definitely help in the future. Thanks again 🙂
Diffus3d
Tyflow is awesome, no doubt.  Glad it worked out for you!  I'll mark your post as a solution so that the next person with this issue has multiple options.   Thanks for posting your solution!
Best Regards,
