Is it possible to walk inside a 3ds Max scene?
I have been dabbling in Revit, was pleasantly surprised when a Freelancer sent me this:
Walkaround Inside Floor No. 6 of Texas School Book Depository Building
BTW: I had no idea that Revit can make videos.
In all my previous models, navigating involved moving the glance/camera around the center of the object, looking into it. When you are inside a room, it is the opposite: you are the center and the glance points away from the center.
The author provided this navigation tip, for walking:
Revit Navigation WheelRevit Navigation Wheel
Question: Is 3ds Max capable of a similar functionality?
TIA,
-Ramon F Herrera
JFK Numbers
[email protected]
irishman_team_kilber
If you draw a line (path) then put a camera on that path then use the go to animate then choose a path Constraint drag the dotted line over to path and your camera will jump on the path then change your camera to a camera view. once you hit the play button you will see your camera walking through your scene
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-a...
