Inventor Server Engine
istan
Advisor Advisor
istan
Since my Max2020 installation stopped working by a really weird error (viewports stopped working - never seen something like this before) I re-installed Max2020 again. Before the IPT/IAM import worked perfectly, but after re-installation of Max2020 the import does not work anymore, no matter how often I re-install this part of software.
Is there anywhere a description about which services need to run and what these services expect in the registry?
btw: the max2016 setup on the same machine still loads IPT/IAM files..
BenBisares
Autodesk Support
Autodesk Support
Try running the following from a command window:
C:\Program Files\Autodesk\3ds Max 2020\Inventor Server\Bin\RegisterInventorServer.exe from a
Let me know if that works.
Ben Bisares
lynn_zhang
Hello @istan ,
Just checking to see if your problem has been solved. Have you tried the above suggestion from @BenBisares and did you have any success? If you find it helpful, please click on the "ACCEPT SOLUTION" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
