AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Importing models from cosmos browser.
armi-lee.amerila
Observer Observer
armi-lee.amerila
Observer
Observer
I'm having issues importing models from the cosmos browser. When I import a model, it shows up in my objects display list, however it isn't visible in my viewport. It shows that the model is in my project but it isn't visible. I've tried unhiding it, rescaling the object, adjusting my system unit setup, and completely starting over in a new project, but nothing seems to work. This issue persists with every single object I try to import.
I was facing the same problem.. I just ran 3d max as administrator and the problem has been solved.
Another solution that solved the problem.. I asked the admin of my PC to move the folder of Chaos Cosmo from (Admin's Documents) to my Document.. and then I changed the path from cosmo bowser. The screenshots provide more explanation.
raiden_xavier
Autodesk Support
Autodesk Support
Hi @armi-lee.amerila,
Thanks for sharing your issue with us.
Did the suggestion from @Anonymous help?
Feedback is always appreciated as it helps everyone.
If the suggestion works you could also mark it as the solution which would be great.
Many thanks.
I hope you are well.
