Import, export problem CAD file into 3d max
afzalneha040
afzalneha040
Community Visitor
Community Visitor
I am using student license and install 3d max 2022. But I face a lot of errors .I can't merge any texture 3d max  and I can import 2d file into 3d max they give a error that I add below please give me a solution.
RobH2
Are the DWG files clean? If they are messy and have errors they can cause problems on import.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
RobH2
Did you  try to clean up your files and import them? Did you solve your problem? If so, write back as to how so it might help others with the same problem.  🙂
Rob Holmes
