I'm having a problem running copitor script
nemo_hamdy
nemo_hamdy
Hi everyone,
I've run Copitor script and after adding the icon to my toolbar whenever i click the icon nothing happens do you have any solution ??
Diffus3d
Which version of 3dsmax is it?  I don't believe it is currently supported on 2024, according to the product page.
Best Regards,
nemo_hamdy
I have 3ds max 2021
Diffus3d
Try running 3dsmax as administrator the first time after installing copitor.  You copied the files to the appropriate subfolders?
Best Regards,
nemo_hamdy
I tried to run it as administrator and nothing happened,
i just drag and drop copitor to the view port and added it to my toolbar as i usually do on any other pc and it always works, but now I don't know what is wrong with it !!
darawork
Just an idea, you might have tried already, but maybe contact the creator of the script?
https://zoffty.gumroad.com/l/Copitor?layout=profile
Usually the creators offer post sales support, just in case something like this happens.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
Diffus3d
I think @darawork is right.  My first guess would be that somehow you didn't have permissions to write the files when installing, and administrator should have fixed that.  Since it didn't, maybe the author can help.
Best Regards,
