How to write some notes inside 3ds max
BubbaDaCaveman
BubbaDaCaveman
Hi, I want to write some notes regarding my rig right inside of 3ds max itself that way it would remain self contained. Is there a way to do that?
Regards.
Diffus3d
Hello @BubbaDaCaveman ,
There's a couple ways you can do this.  There is a popup notes system inside 3dsmax, just sort of hidden.  Here are some other things you can do:
1) I've used Object Properties -> User Defined to store notes before.
2) Maiuu's scene notes
3) File->File Properties can also store notes
4) Or you can make a popup on open which does it.  Might cause problems on a render farm, not sure.  Customize->Customize User Interface -> Toolbars -> All Commands -> Add a popup note
One of those should do it for ya.
Best Regards,
BubbaDaCaveman
Thanks. Option 3 will work for me.
