How to repeat SliceMesh node?
Message 1 of 8
I want to slice a mesh using SliceMesh node. But it only can slice into 2 pieces.
I wonder how can I slice a mesh n-times, where 'n' is a variable parameter. Any ideas?
Replies (7)
Message 2 of 8
Florian.Coenen
with the slice modifier, you just can cut into two pieces.
But you can potentially add a second and a third slice Plane modifier to the object.
Or you can try to cut an object with a Boolean operation. Therefore create a Compound object called Boolean.
I hope that is helpful.
Best Regards,
Florian Coenen
Message 3 of 8
hmm...pretty sure Piotr wants an answer with MCG, not the normal modifier.
I was studying the ASlicer MCG actually, made some mods here:
http://www.scriptspot.com/3ds-max/mcg/mcg-slicerrot
then I looked at the 'Slices' compound to see what's going on in there but haven't quite figured it out yet.
Vu.
Message 4 of 8
Swordslayer
Well, it's actually easier for me to give you a sample modifier for you to dissect than to explain. I'm using Aggregate, feeding it the starting trimesh, applying a function that takes the index of the cut and slices the mesh accordingly, outputing the sliced mesh to be sliced again in the next step. Here you go:
Message 5 of 8
wow talk about timing, without reading your solution first I'll tell you my idea...I'm thinking of a real meat slicer at the butcher shop.
The blade is fixed in place (say origin) I move my piece of meat towards it, it slices a slice off, i'll have to move the rest of the meat a bit more forward, it slices more off, repeat...I got something going but very very crude, I can cut into multiple pieces but the results is far from desirable...But I'll have a look at yours now....I'm sure it works.
Thankyou very much again SwordSlayer, you've been very kind !!!
Vu.
Message 6 of 8
Yes, I got my own version working Swordslayer !!! I will show you when it's a bit more polished...
Message 7 of 8
Message 8 of 8
I am now going to study your aggregate method in details Swordslayer and hopefully learn something fromt it.
Vu.
