How to remove unused maps
mekene
Message 1 of 40
mekene
When I check the Asset Tracking of my scene I see many maps that are no longer used.
This was not a problem until I needed to export an archive of the scene : The ZIP is huge because max includes all those maps.
I looked in materials, environment, background, ... but cannot find where they are used.
What is the workflow to fix such issues. Isn't there a way to determine easily where a given map is used in the scene ? I mean for eg : in the asset tracking, Right-Click a map and give an option to display all objects where this map is being used.
Thank you.
Replies (39)
Message 21 of 40
Jixal
@TB_RIO  try Forensic by Sini software, it's free to use and usually does a great job of removing missing plugins.
https://www.sinisoftware.com/Plugins/Forensic
Message 22 of 40
Jixal
Btw guys n girls. Apparently, 3DS automatically removes any materials or textures that are not being used in the scene. This means that if you still have shaders or texture appearing in the Asset Tracker or Scene Materials dialogue (located in Slate Editor) then that texture or material is still in use somewhere.
The Asset Tracker should have a way to auto-select an object that it is using...... it would make life a lot easier. However, it doesn't so you have to resort to external means. The option I'm using is the Project Manager plugin. It shows you all the textures in the scene and allows you to click 'select object' and bam! It takes you to the object it's associated with. It also allows you to view the shader in the material editor.
If you then remove the shader off any objects that it's associated with and the textures are still appearing in Asset Tracker. Try pressing the scene "Hold" button to force a reset of the scene. And also manually refresh the Asset Tracker or Project Manager, you should see the textures disappear.
Message 23 of 40
TB_RIO
I've cleared out the SME and reset the standard material editor. I use pixamoon's asset trackers for managing scene assets and the only oddity I can see is a couple of maps/materials associated with the UVW unwrap dialogue as mentioned by @Diffus3d  but I can't see how to remove these, I don't think I've even used the UVW unwrap mod so not sure if it is that.
Message 24 of 40
TB_RIO
Fwiw the scene converter removed other missing plugins (that I no longer use) but it can't do it with the mrmaterialattribs.gup
Message 25 of 40
Diffus3d
Depending on your max version, you may not be able to remove the mrmaterialattribs.gup if memory serves.   Does it throw an error when you open the scene?  Should be safe to ignore that one.
Message 26 of 40
TB_RIO
You can ignore it sure, but it gets pretty annoying with it popping up at each render start and opening the file each time. I'm actually pretty worries it's going to screw me over if I have to render on a farm.
Message 27 of 40
Diffus3d
Fair point.  I believe that node is related to when Mental Ray was built into 3dsmax.  I remember some threads about trying to remove it, here is an article by Jon Bell that may help you with this particular bad boy.
Best Regards,
Message 28 of 40
twoods
Okay after a few tries and crashes here is how you do it. It's pretty simple. I'm using 3dsmax 2020, but I'm sure it works on the majority of 3DS versions.
1. Delete and unneeded 3D assets from the scene you want to clean materials out of, save it then rest 3dsmax.
2. Import/Merge everything from this scene into the new scene.
3. Make sure nothing is hidden and select all from the scene.
4. Open the Slate material editor and Get all Scene materials.
5. Save the file.
This removes any unused material references and should now only show the materials connected to the 3D objects in your scene.
Message 29 of 40
BenediZ
Thanks.
This is similar to my approach, just to "export selected" the assets whose materials you want to keep.
and then to "import-merge" only them into a new scene.
Message 30 of 40
Thank you! I had removed every single material in my scene and was STILL getting the error. It was driving crazy!
Message 31 of 40
arqrenderz
So there is no way to keep working on a project and to clean the unused textures¿? I dont really want to import and merge a big project every time i need to clean a file to send it. please Autodesk give us a solution
Message 32 of 40
michael_grosberg
you have to copy it from 2020 and it has to have a very specific folder structure. it took me a while to get all the details right but eventually it worked.
Message 33 of 40
michael_grosberg
There are four places I know of where unused maps might reside:
1. Unused materials in sample slots
2. unused materials in ALL slate editor views/tabs  - some processes create new views without the user's notice
3. maps listed inside UnwrapUVWmodifiers. yes, those count too.
4. background files listed in specific viewports
It should be possible to create a script to clear all of those from a scene in one click. I could do it if I had the time... perhaps I will.
Message 34 of 40
mekene
You are right there is to this day no solution for this, only workarounds.
Some 3D and CAD packages (autocad, sketchup,...) have a built-in Purge function to deal with such issues. 3ds max does not have it. Simple as that.
As long as 3ds max does not have such a function built-in you'll have to live with convoluted workarounds and scripts that only get you halfway there.
Message 35 of 40
darawork
It would be helpful if everyone in this thread pressed 'vote' on these Idea items that were marked for 'future consideration' back in 2017:
https://forums.autodesk.com/t5/3ds-max-ideas/3d-max-heavy-files-purge/idi-p/7049422
https://forums.autodesk.com/t5/3ds-max-ideas/deleting-individual-or-all-unused-materials-no-longer-w...
I myself would love to see a purge feature in 3DSMax, inclusive of the ability to purge all missing plug-ins etc.
Gambling scene files with 3rd party scripts from external websites is not a valid option for professional use.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Message 36 of 40
Keith, How did you remove the un used materials that was gripping onto the unwrap modifiers?
Message 37 of 40
blpjoel
Same. The only way i have found, it to replace each material with a new one, setting all parameters back to the old one. Really awful to do that. Probably can be coded.... but that does work. Missing MR attributes, it's like they didn't ask a single real world user to troubleshoot the beta before releasing.
Message 38 of 40
obaida_ds
IF ONLY , there is something global for (SuperClass TextureMap) in the scene Called "SceneMaps" similar to "SceneMaterials"
Contains All Used Maps in the Scene (Objects, Modifiers, Environment, Renderer, ... etc)
Everything in the scene has SuperClass TextureMap should be within this Array ! .
Message 39 of 40
luizlaval
Observer
Observer
I've found this code in this post about the same problem.
http://forums.cgsociety.org/t/how-do-you-remove-all-unused-materials-from-the-scene-in-max-2015-by-s...
with undo off
	for j = 1 to 24 do meditmaterials[j] = standard()
	for j = scenematerials.count to 1 by -1 do deleteitem scenematerials j
	for j = 1 to (sme.getnumviews()) do
		view = sme.getview j
		view.selectall()
		view.deleteselection()
	savenodes #() ""
It helped me a lot
Message 40 of 40
laomusic_arts
Hi!
All the "solutions" here point to  3rd party scripts/software, an NONE OF  THEM really works flawless.
But don´t worry, the software engineers at Autodesk has it all under controll!
Here is their/mine simple solution:
- open the scene in question, with extras maps/textures
- under the menu File/Archive and point to the folder "archives" under your Project folder
- a Command Line will collect, compress and save all files used in the scene.
- go to your Project folder/sceneassets/images and delete all maps
- unpack all maps back to this location, from the archived file
There you have it! Keep it simple.
