Maxscript below to get you started, courtesy of Miauu:
-- Created: 05-08-2013
-- Last Updated: 05-08-2013
-- Version: 1.00
-- Author : Kostadin Kotev / miau_u@yahoo.com / http://miauumaxscript.blogspot.com/
-- Version: 3ds max 2009 (10) (should work in older versions too!)
-- Discription: Hide objects by category
-- If nothing selected will make all objects visible.
-- If spline object is selected it hide only the spline objects
-- If light object is selected it hide only the light objects
-- Usage: RUN IT
-- MODIFY THIS AT YOUR OWN RISK
macroscript miauuHideByCategory
category:"miauu"
tooltip:"Hide By Category"
buttonText:"Hide By Category"
curO = selection[1]
if curO == undefined then
hideByCategory.none() -- show all
else
try
case (superclassof curO) of
GeometryClass: (hideByCategory.geometry = true)
Shape: (hideByCategory.shapes = true)
Light: (hideByCategory.lights = true)
Camera: (hideByCategory.cameras = true)
Helper: (hideByCategory.helpers = true)
SpacewarpObject: (hideByCategory.spacewarps = true)
case (classof curO) of
PF_Source: (hideByCategory.particles = true)
PCloud: (hideByCategory.particles = true)
Spray: (hideByCategory.particles = true)
SuperSpray: (hideByCategory.particles = true)
Snow: (hideByCategory.particles = true)
Blizzard: (hideByCategory.particles = true)
PArray: (hideByCategory.particles = true)
Biped_Object: (hideByCategory.bones = true)
BoneGeometry:(hideByCategory.bones = true)
)catch()
https://www.scriptspot.com/3ds-max/scripts/hide-by-category
Or, in the case of the filters, I could only find this:
for i = 1 to GetNumberDisplayFilters() do
format "%: % : %\n"i (GetDisplayFilterName i) (GetDisplayFilter i)
1: Non-Corona : false
2: CAT Bone : false
3: Bone : true
4: IK Chain Object : false
5: Point : false
https://forums.cgsociety.org/t/accessing-the-hide-by-category-multilistbox-with-maxscript/2054010
Although, this is for an older GUI version, I presume the Maxscript hasn't changed.
Also, here is the official AutoDesk Documentation on the subject:
https://help.autodesk.com/view/MAXDEV/2022/ENU/?guid=GUID-97C887B6-CE4D-46EB-AB10-BE3A9DC2F69A
*Please note that the filter callbacks are only available in 3ds Max 2021.1 Update and higher.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
This does not apply to 3dsmax2022
Did you manage to find out the 'API' (Maxscript) yet?
"*Please note that the filter callbacks are only available in 3ds Max 2021.1 Update and higher."
Best regards,
Darawork
AutoDesk User
