How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Please notice this screenshot.
The grids on the righ side aligned well
It is only a prototype, for a future project. In order to simplify some drawing I need the 3 grids to have the exact same separation.
In the screenshot, I was able to align the top-right and bottom-right grids. However, the 2 grids at the bottom are not aligned precisely.
The only way I know to zoom in/out is by using the mouse wheel. Perhaps I need a way to make finer adjustments?
-Ramon F. Herrera
JFK Numbers
To be sure: What I need to learn is a way to make all the grid squares of the same dimensions.
TIA,
-Ramon F. Herrera
JFK Numbers
@Anonymous
You set the grid spacing via Right click on Snaps toggle and then selecting "Homegrid". The grid size (spacing) for all viewports is set here and it is the same for all viewports. You can prove this to yourself by opening a new scene and changing the grid size to a different value. You will see all viewports simultaneously update with the new spacing you have chosen. When you zoom in on a particular viewport, the grid lines naturally will appear to be farther apart, but the actual grid spacing has not changed. Same thing when you zoom in on a box of say 24 x 24 x 24 units. It will appear larger in the viewport, but it's actual size hasn't changed.
How to buy
Type a product name
