How to import FBX file with correct orientation
Hi, I have imported FBX to 3ds Max.
The FBX file is created from Navisworks Manage. Here is the top view for FBX in Navisworks Manage:
Navisworks Manage top view
However, when I import FBX to 3ds Max, the orientation has changed. Here is the top view in 3ds Max:3ds max top view
Here is the FBX import settings I have used when I import FBX in 3ds:FBX Import Settings 1FBX Import Settings 2
I could not find FBX import settings which specify rotation or orientation.
Could anyone please guide me how to import FBX with correct orientation? I have attached a sample FBX file here.
Thank you.
Replies (7)
Dear all, anyone has experienced this problem before?
Thank you.
Alfred.DeFlaminis
Hello @Anonymous,
This seems to be an issue with how Navisworks sees scenes with Z as Up axis.   (Navis uses Y.)   The FBX is importing as it's being written, so I think the fix is in Navisworks.  I don't know that software at all, but I did find this article which explains how to set coordinates in Navisworks.  Seems like if you made some adjustments there it should fix the problem.
In Max you could just rotate the helper that everything is parented to 180 degrees on the Z to get the same results.
Can you please try those things for me?
Best Regards,
@Alfred.DeFlaminis, thank you for your response.
I have checked with the NWD file author and the coordinates shown in Navisworks are correct.
How do I rotate the helper?
Could you please show me some guidance in doing this?
Thank you.
Alfred.DeFlaminis
Hello @Anonymous,
According to that article, Navisworks uses Z as up which is the same as Max, that's great.  It uses +Y as North.  This should be the same in Max but your entire model seems to be rotated 180 degrees.  So maybe setting -Y as North will fix that.  Worth a shot.
Otherwise you can select the helper that Navisworks is putting in your FBX at 0,0,0 and use snapping to rotate it 180 degrees.  I made a screencast to show this to make it easier to understand.  Please let me know if you have any questions.
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
@Alfred.DeFlaminis, sorry for the late response.
I managed to try your method and it works well.
Thank you for your support!
@Alfred.DeFlaminis , is there any script available for me to the same actions you have shown in the video (import the FBX and then rotate the model)?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
