How to disable cloud rendering 3ds Max
I have accidentally pressed render in cloud button on the interface and now I can't go back to a regular Render set up properties. Every time I hit render production it tries to render in cloud. Can anyone, please help me to disable this feature? Or at least go back to a default Render set up. Please find a screenshot with the Render set up I currently have.  Many thanks, Tatiana
spacefrog_
The solution is right there in the dialog visible in your screenshot
Simply click the first, topmost dropdown button (right next to the "Target" Label) and you'll get a list of the other available render modes. Pick "Production Rendering Mode" ( usually the first entry)  from the list and all should be back to normal
Josef Wienerroither
Software Developer & 3d Artist Hybrid
Thank you!
but still its not working. when i keep post production automatically it sets in to cloud rendering wat to do????
PierreEFT9S
Observer
Observer
Yes,
I am also having the same problem and it is not solved. Any ideas?
Hello! I thought I would share how I fixed this issue, this thread is a little bit old but I thought it's probably still appropriate.
So for anyone who is having the issue still, I followed the steps above and changed my Target from A360 Cloud Rendering Mode to Production Rendering Mode, and then scrolled to the bottom where you can find the Assign Renderer menu, for me it still said A360 Renderer on it, so I clicked the 3 dots and changed it from A360 to Default Scanline Renderer 🙂
Hope this helps! I've included some images below of what i mean
