How to create editable poly shortcut
How can i set shortcut to editable poly because  in the
Customize User InterfaceKeyboard  there are just Edit Poly Modifier
@Anonymous
You want to add a shortcut to (editable poly modifier )?
Thank you for your answer
I want add shortcut to the editable poly not to the editable poly modifier
@Anonymous
t.pngahaaaa you mean convert to editable poly ??
ok you can create shortcut for it but search for (c) not (E) because it is convert...
1.PNGas shown in second screenshot
Thank you so much for your help
