How to complete delete 3ds max on pc
I tried to move 3ds max to my new ssd disk and i couldnt start it, so i tried to delete it and reinstall. Problem is that when im trying to install it, it say that 3ds max is already installed..... I have deleted every file i can find on my pc, but it just say "INSTALLED".... How do i complete uninstall it?
irishman_team_kilber
you need to use the add/remove in control panel and then uninstall 3ds max, backburner and whatever else is associated with 3ds max,
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/CloudHelp/cloudhelp/2017/ENU/Ins...
There is nothing in control panel cause i removed it before.... I have tried deleting all files where i know it can be and still its not deleted...
if you have a windows OS there is a control panel unless your using a mac?
No i mean, i have already deleted 3ds max from controll panel
https://forums.autodesk.com/t5/installation-licensing/cannot-fully-uninstall-3dsmax/td-p/3786865
See if this thread helps first try rebooting your computer if it still doesn't work then have you tried booting up the splash screen installer, repair and uninstaller to remove it that way
