How to change hotkey Win Shift Tab?
How to change hotkey Win Shift Tab? I try to do windows screen but 3ds max open Vieport Cycling.
DanielCantin
Hi @Anonymous
I'm not sure I understand your question, are you trying to access Windows app switching from 3ds max, if it is the case, should you not use "Win+Tab" or "Alt+Tab". "Win+Shift" in Max do the Viewport Cycling and is not customizable.
I could not find reference to "Win+Shift+Tab" in  windows keyboard shortcuts list , please let me know if I misunderstood your issue.
Thanks for reaching out, please let us know if that solve your issue or not.
Daniel Cantin
QA Manager, 3ds Max, Maya
Entertainment Creation Products, ECP
joseph.stoneZH7T5
Community Visitor
Community Visitor
I believe the OP was referencing the shortcut key Win + Shift + S for example takes a screenshot in windows.. If you try and capture a screenshot with max in focus it will bring up the swap view shortcut which Autodesk has decided to map to Win + Shift for some silly reason.. (Win key shortcuts are reserved for the OS!).
david_montanaJZMD9
Community Visitor
Community Visitor
I have not found a solution, I don't know who came up with the idea of ​​using a shortcut that Windows uses to take out a screen or to change the scene view
sadeghm
Community Visitor
Community Visitor
In 3ds Max, Shift+Win+S is a fixed shortcut that can't be changed. To avoid this issue, try not pressing all three keys simultaneously. Instead, hold Shift first, then press Win and S separately.
ladang106cuy
Community Visitor
Community Visitor
Thanks for the tip! It’s helpful to know that Shift+Win+S is a system-reserved shortcut. Holding Shift first and pressing Win+S separately is a simple workaround that should prevent conflicts while working in 3ds Max.
mp3 juice
