How do I mirror a unwrapped model
mezimforte79
mezimforte79
How do I mirror a unwrapped model without problems with inverted uv shells
I am faced with this problem and I can't find a way out of the situation. the objects are repeated and so I would not like to repeat the same sweep several times. I ask for advice from knowledgeable people. help me
I checked with xview and rizomuv reversed uv shellsI checked with xview and rizomuv reversed uv shells
Diffus3d
Maybe you want to clone it instead of mirror it?  Why mirror it at all if it's symmetrical and you want original uvs?
Best Regards,
mezimforte79
the screenshot I gave just for example in reality I have a symmetrical complex object, you see cloning will only help if the object does not have any individual geometry features, for example a spaceship is modeled symmetrically but then I delete part of it and make a mirror copy and there this problem with the inverted uv shell
advise me if there is a solution with the standard tools?
mezimforte79
that there's no one to help?
Diffus3d
The best way I know is to reset the Xform and then flip the UV's horizontal.
mezimforte79
all these methods do not make the work of the specialists any easier, and I think that Autodesk will solve this problem with the next patch
