Hiding/unhiding/selecting multiple objects using Scene Explorer
Long-term Max-user, but new to Max 2016, so forgive the slightly n00b topic here. In Max 2014 and earlier, I used to be able to use 'Right Click > Unhide by name' to bring up the Unhide Objects dialog, in which I could use the mouse cursor to drag select over multiple objects in my list and unhide them. As of 2015, I understand Autodesk have introduced a new Scene Explorer which "makes scene management easier". In which case, could somebody please inform me how I can still drag select multiple entries in the list in Scene Explorer/Unhide Objects to hide/unhide/select them in my scene? It seems as though I now have to click on each object individually with the mouse...surely I'm missing something exceptionally obvious?!
Any help would be much appreciated!
Jack
gandhics
Drag mulri selection is changed to reassign layer and relink.
To select multiple object, select first one and SHIFT+last one like you do in windows explorer.
Then click one of visible button to hide/unhide.
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
No worries, you can disable the scene explorer and go back to the old school list select.  I work this way myself, so I understand exactly what your issue is with the scene explorer.  To do this:
Go to:  "C:\Users\%username%\AppData\Local\Autodesk\3dsMax\2017 - 64bit\ENU\en-US\defaults\MAX\CurrentDefaults.ini"
and change the following line:
SelectByNameUsesSceneExplorer=1
to
SelectByNameUsesSceneExplorer=0
While you're at it, you can get your old material map browser back by going to:
"C:\Users\%username%\AppData\Local\Autodesk\3dsMax\2017 - 64bit\ENU\plugcfg_ln\SME.ini"
and changing the line
UseOldMtlBrowser=0
to
UseOldMtlBrowser=1
Please let me know if you have any questions.
Best Regards,
Hi Alfred,
Thanks for this alternative - it certainly makes life a little easier! But wow - this certainly is the OLD school select list! It would've been nice to have somewhere between the two - the UI of the select list in the versions prior to 2015 was useful. But beggars can't be choosers!! Seems strange that this multiple drag-select is restricted in the newer versions though.
Anyway, thanks again - your help has been much appreciated!
Cheers,
Jack
Alfred.DeFlaminis
Hello @Anonymous,
I prefer function over form personally but I can relate.  A little secret is you can have this menu up at all times by setting a button somewhere with the following item.
Best Regards,
