Announcements
Hide group members?
roger.olofsson
Hide group members?
roger.olofsson
Is it possible to hide the group members in scene explorer but still have the group visible?
Roger
MartinBeh
One could probably script a custom filter for Scene Explorer to do that, but this would need better specification of what exactly should be shown and what not. Probably not every element of your scene has something to do with groups...
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
miauuuu
Open the group and hide all of its members. The selection brackets of the group will "shrink" to a 2d plane but it will still be visible in the viewport and you can select it.
https://miauu-maxscript.com/
MartinBeh
Run this line of MAXScript code:
SceneExplorerManager.AddReadOnlyProperty "GroupHead" isGroupHead
Then open Scene Explorer, go to Display > Configure Advanced Filter
Open the 'Property' dropdown menu and select the entry "GroupHead" (probably at the bottom of the menu)
Under 'Condition', select 'Starts With' and under 'Reference Value' enter 'true'
--> all objects that are not the head of a group are no longer visible in SE
You can toggle this on/off using the filter icon (3rd from the bottom) in the left toolbar of SE (or go to Display > Enable Advanced Filter)
MartinBeh
Or a little bit nicer:
SceneExplorerManager.AddReadOnlyTypedProperty #boolean "GroupHead" isGroupHead
miauuuu
Yep, my head was somewhere, over the rainbow. The OP asks about Scene Explorer, my answer is about the viewport.
