HELP!
This widget could not be displayed.
HELP!
Hello everybody,
please help me on this issue:
I use vray software to render my projects.
Whenever renderizava some project, appeared to
message '' Raytrace messages '' and looked on youtube, google,
how to remove it. And I saw a tutorial of a person talking to go
this bar '' Customize> custom ui and defaults switcher> max.vray>
defaultUI> set.
After I did that, the impression I got, it's like 3ds max,
resetou the settings that were in it and returned from scratch.
So much so that the settings for rendering the vray, too.
Set up again the render in vray, as always use
and that is perfect pictures, and when I do a render
a scene again, it was very strange, got lots of noise
being that the settings of 'adaptive subdivision sampler image' and
everything else, are right.
I do not know what happened, follow the images so that you guys can help me,
how it is getting now my surrender.
In one of these img, q vc will repair .. has a render before I have done
this '' goofed '' and after that ...
CAMedeck
I don't know how changing the defaults would have changed your images.  The images you attached are small, and it is difficult to see what the issue is with your rendering.
On the building wall outside, is the texture set to use Real World Coordinates?  Did the scale change?
Chris Medeck
Believe me, even these images, with small before,
the same size, they were perfect.
Note the roof of the house and the wall of the
building, as is their large noises.
And I think that is not the question of the proportion
also because projects are created in real sizes.
Thank you for answering.
