Hdri problem
Hdri problem
Hdri problem
Hello to everyone!
My problem is that the light of hdri cannot be seen at 3d studio max while rendering. Not only everything is pitch black, but the slot of the hdri in  material editor is black ,too. Plus i realised that the hdri file ,inside my archives of hdris, when opened by max in order to be put in the environments and effects, it is just white , while it should say hdri, ( see picture below). I use corona render if matters
My pc at home works perfect, the problem is  the pc at work. I am new there, and i cannot figure out what is going on.
Thank you very much in advance
raiden_xavier
Autodesk Support
Autodesk Support
Hi @Anonymous
I see that you are visiting as a new member to the 3ds Max forum. Welcome to the Autodesk Community!
Thanks for sharing your issue with us.
I have some thoughts:
  • Image attachment is too small for me to view.
  • What version of 3ds Max is being used? Any updates applied?
  • Do the Environment render settings match?
  • Sometimes black previews are because the active render is different. For example: at home you have Corona set to active, but at work it may be set to Arnold or VRay.
Apologies if I misunderstand.
RobH2
When you copied the HDRI to take it from home to work, is it possible that the file did not copy correctly? If you open the HDRI in Photoshop at work, what does it look like?
Rob Holmes
3ds Max (2023-2026), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
